1 - 3 of 3 Posts
So i recently bought a 2007 BMW 335i e93. It came with a shit ton of problems...... One of the problems i noticed was a SOS light on the dash. I began digging to find the stock amp wasn't plugged in and was sitting in a puddle of water... and the cables were all cut. I went online and bought a used amp, and a new harness to connect back to the old one that was cut. After receiving the harness i realized it was for a e63. Some of the colors were different and it has extra wires. Would i be able to just wire a whole different aftermarket amp? Or what is the best think I should do. Pictures of what i have below... (( 1st Picture - Green Harnesses. 2nd Picture - Cut Stock Harness Wires. 3rd Picture - Logi 7 AMP (I Purchased). 4th Picture - e63 harness. 5th picture - Stock Cut Harness Plug ))
Hand Gesture Finger Thumb Automotive tire
Hand Finger Electronic engineering Technology Electrical wiring
Gesture Art Creative arts Electrical wiring Technology
Circuit component Gesture Finger Electronic component Electrical wiring
You have numerous posts how to connect amp. Water is common in that area if maintenance neglected.
Installing aftermarket amp requires much more than just plug and play. If you just want sound, find used amp that fits your part number.
If you want more, there are numerous posts about that in e90post.com forum. Ctuna will help you with that.
If you want much more, aftermarket is best solution but requires much more than just amp.
They use the same three sound systems throughout most models.
There may be some small eq differences.
Wiring Diagram-l L7.jpg (JPEG Image, 600 × 724 pixels) - Scaled (77%)
LOOP | BAVLOGIC, LLC
See the link in the above link that says
BMW Logic 7 Amplifier Information
TOP-HIFI SYSTEM AMPLIFIER
HiFi System Professional DSP
You can add a aftermarket amp if you know what you are starting with
but there are some things that make it difficult espcialy with a Logic 7 system.
Due to the Fiberoptic connection between the Head Unit and Amp.
Also the Logic 7 amp is 9 channels so if you want to drive all locations the closest thing is and 8 channel amp or amp DSP.
Best to take your question's to he e90post.com stereo subforum.
BMW stereo types E9X audio systems defined - BMW 3-Series (E90 E92) Forum - E90Post.com bmw oem audio systems tis.pdf http://www.e90post.com/forums/attach...2&d=1260829447 attachment.php (JPEG Image, 540x707 pixels) - Scaled (91%) http://bmwcoders.com/forum/3-er-8/bm...1-e92-e93-291/ BMW OEM Audio and Integration Expert Our Approach « Musicar Northwest http://www.e90post.com/forums/attach...3&d=1169133185 attachment.php (JPEG Image, 600x724 pixels) - Scaled (88%) Audio Table of Contents: Upgrading? Start HERE! - BMW 3-Series (E90 E92) Forum - E90Post.com http://www.e90post.com/forums/attach...4&d=1278871872 Aftermarket Replacement Speakers List - BMW 3-Series (E90 E92) Forum - E90Post.com (20) Exploring the Individual Audio / Enhanced Premium Sound - Option 752 | Bimmerfest BMW base system wiring pre/post 3/09 http://www.e90post.com/forums/showth...1#post16679904 Base System Guide http://www.e90post.com/forums/attach...5&d=1493273253
1 - 3 of 3 Posts
