After a bit of a hiatus and overwhelming amount of backorders, aurora is now back in stock and ready to ship.
History:
We have seen lots of Angel Eye kits on the market in the past 5 years. Everything from separate lightsources, CCFL tubes, failing inverters and LED kits with gaps and warranty issues with vendors and kits that do not fit. What happens when you can't find something for your BMW on the market that suits your needs?
You simply design them yourself.
Introducing aurora, an entirely redesigned angel eye kit for your BMW from eas - unlike anything else on the market.
aurora produces a fully uniform look using a 60 LED array, which matches most Xenon maps for an OEM look and are very bright - these can even be seen in daytime. You will immediately know another vehicle with a set after yours are installed. Originally debuted on the 2001 5-series and M5, Angel Eyes became a signature lighting upgrade for all future BMWs. Now you can easily equip your BMW with the same look, but at a much brighter LED light output when finished and without external inverters to short out.
Appearance
A light-emitting diode, usually called an LED, is a semiconductor diode that emits incoherent narrow-spectrum light when electrically biased in the forward direction of the p-n junction, as in the common LED circuit. This effect is a form of electroluminescence. A LED is usually a small area light source, often with extra optics added to the chip that shapes its radiation pattern. LEDs are often used as small indicator lights on electronic devices and increasingly in higher power applications such as flashlights and area lighting.
aurora angel eyes produce a white light using an array of
60 LEDs spaced evenly apart for a uniform look, giving a slight blue tint, which matches most Xenon maps for an OEM look and are very bright - these can even be seen in daytime. You will immediately know another vehicle with a set after yours are installed.
Look Ma, No Gaps!
aurora emits its light from a 60 LED array for a uniform and finished look. aurora angel eye LEDs do not use a magnified lens like our competition to "cheat" on brightness. aurora's rings are designed to properly diffuse the light for a more uniform, complete look without "pearl necklace" or "burnt out Christmas light" syndrome and giving a closer OEM like look and feel. Magnified lenses also enhance the LEDs when unlit, a properly diffused lens like used in aurora will hide these LEDs during daytime.
Dual-Stage Ring Clipping mechanisms
For years, angel eye users have been plagued by clips that simply do not fit correctly - we have a solution. Our 2-stage replaceable clips allow secure clipping onto your headlight housings without the need for "spacing" or guessing alignment, especially for those with adaptive headlamps. Simply clip into place and rest assured your rings will be sure without the need for gluing or falling off from road vibration or adaptive headlight movement.
If clips are ever broken, replacements are available without replacing an entire kit.
OEM Look
aurora halos feature a sleeved highly polished ring around the circuit board, giving a thicker more OEM look when on or off. Since LEDs are directional, there is no "bleedoff" in light direction allowing for maximum light output facing forward.
Safety
A Heavy duty wiring harness is included to make installation quick and painless, while adding safety to your install. No light boxes or lamp sources are used unlike older kits. Installation takes about 1 hour and will be one of the favorite mods on your BMW. Aurora v1.1 now uses external driver packs which are potted for weather/moisture resistance unlike our competition.
Simply the BRIGHTEST angel eye rings on the market
aurora angel eyes can be seen from well over 150 feet away in pure daylight - they are BRIGHT. Using high-powered LED technology, these are the brightest on the market. With a highly polished ring engineered to emulate the OEM ring when not lit, these will look as if your BMW were equipped with Angel Eyes from factory. Kits are engineered using high quality components and are rated at over
100,000 hours or
10 years of continuous illumination.
Remote feature
aurora angel eyes feature a remote feature that will automatically dim the rings when you enter or leave the vehicle. Unlocking the vehicle will emit a "fade in" and will fade out when the vehicle is locked or if left dormant for over 15 minutes to prevent battery drainage.
LIFETIME Guarantee
There's nothing worse than having a kit that will not work, for those that have purchased other kits elsewhere and have dealt with frustrating return processed or no warranty at all, we feel your pain. eas backs up all aurora angel eye kits with a limited lifetime warranty, making this the first and last set you will purchase for your BMW. if you should ever experience a problem with your kit, we will be there to help.
Features
- 15% brighter than previous aurora angel eye kits, outshines any other kit on the market - including Orion II.
NO GAPS present when lit
- OEM like modern look, simply the brightest kit on the market
- Even, uniform light distribution throughout rings, with no gaps present
- Proprietary ring design used for uniform and even light dispersion throughout angel eye rings
60 high powered LED array for maximum brightness, withstanding shocks, vibrations, frequent switching and extreme temperatures
- CAD designed polycarbonate ring with UV protection and additional clearance for all headlight housings
- No dangerous light boxes or heat fixtures to mount, keeping safety and cleanliness underneath your hood
- No "cold weather" start problems
- Instant transformation to appearance of vehicle after installation
- 100,000+ hour life (over ten years)
- Easy installation
- Compatible with Halogen, Xenon, Auto Leveling and Adaptive Lights
- Limited lifetime warranty
Kit Contents
- 4 Highly polished LED Halos
- 1 Heavy duty wiring harness, with remote feature
- 2 High power LED driver packs
- Backed by eas
Lifetime warranty
- Detailed instructions
Models Supported:
1999-2003 e46 3-series Coupe (pre-facelift, non-sealed lamps)
1999-2005 e46 3-series Sedan
2000-2006 e46 M3 Coupe/Convertible
e2 - aurora 60 LED Angel Eye Kit - e46 3-series, including M3
http://www.europeanautosource.com/product_info.php?products_id=1883
Thanks for looking, all weekend orders have already shipped out.
