1 - 2 of 2 Posts
european auto source
We are proud to announce the introduction of Streamline Performance Air Filters to our lineup.
Helene Performance specializes in high quality, high performance and high protection original equipment direct replacement air filter panels for select vehicles. Every Helene Performance Streamline™ SE panel filter is designed to the specific requirements of the engine it will be protecting so you are not getting just another mediocre one-size-fits-all design. Pleat depth, quantity and filtering media configuration are tuned to provide the best possible performance without compromising the protection required for today's high tolerance engines.
The Streamline™ SE panel filter is the ultimate tweak for someone that wants to maintain and improve upon the highly engineered stock intake systems.
This is an engineered filter. Not just another universal washable filter! You are proud of your high performance vehicle so now get a panel filter of the same caliber.
Maintaining proper CFM flow and particle capture efficiency is a delicate balancing act. Filters that flow well usually do not protect as well and vice versa. Helene Performance has mastered the formula to achieve this elusive perfect balance and so your engine assets will perform better without sacrificing protection. This filter is serious equipment for serious cars.
Features of the Streamline SE panel filter:
- Direct replacement for original equipment filter panel. No modifications required
- Tight leak proof seal with the air box
- Easy and fast installation suitable for novice requiring only a screwdriver at most
- Deepest multi-layered pleats increase air flow and maintain critical protection levels
- Maintains OEM filter's 99% debris collection efficiency per ISO 5011 standards
- Maintains BMW engineered pressurized air box and stock appearance
- Sturdy sidewall construction ensures filter will last the life of the vehicle
Streamline™ SE Panel Filter - e46 M3
http://www.europeanautosource.com/product_info.php?cPath=67_334_338&products_id=1222
Streamline™ SE Panel Filter for most BMWs
http://www.europeanautosource.com/product_info.php?cPath=67_334_338&products_id=1223
For those running K&N or Dinan Cold Air intakes, we have replacement filters for you also:
Streamline™ SE Cone Filter - Dinan Replacement
http://www.europeanautosource.com/product_info.php?cPath=67_334_337&products_id=1225
Streamline™ SE Cone Filter - K&N 63 Replacement
http://www.europeanautosource.com/product_info.php?cPath=67_334_337&products_id=1224
These are widely known as the best filters in the industry and are in stock and ready to ship immediately. :wave:
1 - 2 of 2 Posts
