1 - 9 of 9 Posts
Hey guys, I contacted ECS customer support but they were unable to confirm that...
the bushings in this this kit: http://www.ecstuning.com/BMW-E46-325xi-M54_2.5L/Search/SiteSearch/Ecs_Teflon/ES259532/
replace this/these: http://www.ecstuning.com/BMW-E46-325xi-M54_2.5L/Search/SiteSearch/Shifter_Bushing/ES47190/
So my questions...
1) Am I correct in assuming that those teflons bushings replace those shifter bushings (25117519670)?
2) I am aware that the car calls for 2 bushings, does that teflon kit replace both or do those 2 pieces only replace one bushing?
Sorry if this is obvious, I am new to this car (01 325xi) and BMW! Thanks!:dunno:
Discussion Starter · #2 ·
Ok, so the attached chart seems to indicate I was right about question 1 (that the teflon kit replaces 25117519670), but it seems to me you would need 2 sets (one for each side, but regarding the 2 guide pins... there are 2 different part numbers for the guide pins, so I assumed they were different from one another... So how would this kit work for both?). Unless someone knows for sure I guess I will just replace the bushings with OEM parts. Thanks!
You might want to read up some where people bought those and didn't seem to like them for some reason. I was going to order them when I did my shifter on my car but after what I read I went with the oem rubber ones from ecs instead of the Teflon ones.
Discussion Starter · #4 ·
Cool... Yeah if I need two sets I don't like the price too much anyway, and don't really see a need to replace the pins at this point anyway... shifter still pretty solid, but I am doing the clutch (168K miles) soon, so I figured I might replace some things. OEM!!!
Thanks for the feedback. Cheers!
Shaft arm bearing (#5) would be a good "while you're in there" candidate too.
Keeping it surreal
Or, just replace the whole shifter with a unit from a Z4....relatively cheap, and a good performer....:thumbup:
Discussion Starter · #7 · (Edited)
Yup... That's my plan! I plan on reusing clips and pins unless someone talks me out of it...
shifter arm bushing - 25111222015
shifter bushing x2 - 25117519670
shifter rod joint - 25117580281 (thought about skipping this, but read it was a good idea to replace)
shifter ball bushing - 25111220600 (this is the white bearing)
e60 shift lever - 25117546373
There's my list, just in case anyone stumbles here and needs the info. I'M OPEN TO FURTHER ADVICE!!!!!!
You had to do that just when I thought I was starting to understand, didn't you? haha
edit: it doesn't seem to work with the xi...
Thanks for chiming in! I'm looking forward to learning this car as well as my dearly missed Prelude...
Instructor of the Stig™
The kit you're looking at in the original post was incorrectly set to your car, I'm very sorry about that. HERE is a link to the correct kit for the E46 325xi. This kit is going to contain 4 teflon bushings (2 required for each standard rubber bushing) and the two guide pins for the E46 325xi.
-James
Discussion Starter · #9 ·
Thanks James!
1 - 9 of 9 Posts
