setup- I have a 2009 X5D (u.s.) with 123,000 miles and JR Auto tune that is supposed to have EGR programmed permanently closed/disabled. I've had it for approx. 10,000 trouble free miles (the tune, owned the car since 44k).
the idiot light- I got a Check Engine Light and pulled the code using iCarly Pro for BMW... the code was under the engine category (004C87) that stated "Low pressure exhaust gas recirculation cooler reduces cooling efficiency."
the question/ problem- is this code valid due to the stage 2 software supposedly eliminating the function of the EGR? or is there something else wrong? ....furthermore, what would you experts recommend? Eliminate the system now? replace the supposed failed low pressure cooler?
The car still seems to run perfectly minus the dash light staring at me. I googled and searched for this specific code and can't find anything specific... has anyone seen this error and symptom?
Thank you all in advance for your advice and help.
-Jeff
-Jeff
