I jumped the wires on connector and fan comes on, replaced the temp sensor in radiator, made no difference. Also, it does not come on with A/C turned on. At what temp is this to kick on? gauge stays right in the middle of gauge. Just purchased this car and received paperwork that shows stat being replaced at dealer recently. Took readings on hoses, stat housing, radiator with temp gun, and nowhere is over 205 degrees. Thought I saw somewhere these has a 215 deg. stat, but even so it should still kick in with A/C on I would think. Any help out there, before I wire it to a switch.
Thanks, Gene
Thanks, Gene
