In Texas, you might benefit. BUT, it will all depend on your driving conditions and what the electric replacement will do as far as CFM rating. If you find an electric with no lower a CFM than the belt fan and a very good (nearly sealed) shroud... Since you are where you are, do NOT let anyone tell you a "fan delete" is a good idea.I have a '95 325i and was thinking of switching my stock shaft driven fan for an electric one. what do you guys think?
thanks,
travis
I've heard this. But I don't understand how it can be. The power has to come from somewhere, and that's mechanical loading on the alternator. Plus total losses. So for the same mechanical "air pushing" blade power available, there's a larger engine load overall.Well, an electric one is nice to get the draw off the engine. But they're pricey and you need a good one. Of course, the mechanical fans are known to explode occasionally, too. Details, details.
TRAVIS,I have a '95 325i and was thinking of switching my stock shaft driven fan for an electric one. what do you guys think?
thanks,
travis
You are not wrong. The power does have to come from somewhere and it's NEVER free. There are a scant few electric fans that move as much air as the belt driven one and they are NOT cheap. In purely design terms, the benefit of the electric fan is space savings.I've heard this. But I don't understand how it can be. The power has to come from somewhere, and that's mechanical loading on the alternator. Plus total losses. So for the same mechanical "air pushing" blade power available, there's a larger engine load overall.
The voltage regulator will cut in and out as required; you don't get to choose when.
I can though see how an electric fan (or lack of a constant mechanical one) allows the engine to rev up at a higher rate - as long as the alternator is not heavily loading at that time.
I don't think the maths add up. If I'm wrong I'd like to learn how it really works.
