1 - 6 of 6 Posts
I have a check engine light.After I check the code I found I need an oxygene sensor I changed it and the light is still there.After I clean the code is still pops up.Can someone help me read the digital multimeter should it be on the dcd,acd or dca.
The code should have indicated which sensor was bad, and, I assume, you changed that sensor.
Did you buy an OEM Bosch sensor, or something from ebaY?
Freude am Fahren
Torqued it right? What are the codes.
Output should be 0.5-1.0 iirc at idle.
1 - 6 of 6 Posts
