OK,
So due to some issues I let my 1999 528IT 5 speed sit for about a month,
Its been a great wagon which I typically used for my weekly 600 mile highway drive across the state.
Ive had a ACS light on for about a year due to the module, But all else has been fine and working well,
So today I jump in it,
The EML light is on, The temp gauge reads full hot and the AC compressor won't turn on, All else words as it should,
While sitting in the car the EML light flashed off and the temp needle returned to center and then EML light back on the temp needle went right back to full hot,
The wagon has about 180K miles,
The cooling system has been replaced and it is not running hot,
The only thing which happened in recent history is that the Exp tank blew on a bad factory seam and filled the engine compartment with nice hot antifreeze steam, I replaced the tank and did 1200 miles on it worry free since then.
So now this goofy stuff is going on and I need to start to run the car again in two days, 300 miles across the state and back again in a few more days,
Is there anything I can clean of check?
No CEL light on at this time,
Just the dang EML light,
AC is filled with R34 and has never leaked, At this time there is pressure in the system buy my Gauges are at work so I don't know exactly how much or if the two things are related somehow,
Any and all suggestions will be checked as swiftly as my job will allow,
Thank you,
Peter B
Thank you,
Peter B
