Enable BMW apps by coding ?
114K views 521 replies 215 participants last post by  shawnsheridan
#1 · (Edited)
hello every body,
I just received my new 520i car 2014 two days ago. I'm newbie in coding but succeed to connect with e-sys and read data.
I'm in a country where connected drive is not available. however my car is equipped with
Can I by coding activate bmw apps and connect internet by phone connection sharing?
Thank you
#426 · (Edited)
@shawnsheridan
Hello,
I have a question, my 2012 F10 has options for connected drive but it never works, I paired my iPhone and enabled internet hotspot via bluetooth, when I press on ConnectedDrive it shows loading and after 5 minutes tells me is not possible and I have to call BMW, when I try to add my VIN in BMW Remote app it tells me the car is not supported.
I have called BMW and they told me is impossible to make it work because I have old equipment and also these features were working only in France.
Is there a coding way to enable them ? I am interested in BMW Remote app on iPhone.
My car has these options related to connectivity
S609A Navigation system Professional
S612A BMW Assist
S615A Extended BMW Online Information
S616A BMW Online
S633A Preparation, mobile phone, Business
S676A HiFi speaker system
S698A Area-Code 2 for DVD
S6AAA BMW TeleServices
S6ABA Control, Teleservices
S6VCA Control, Combox
#427 ·
@shawnsheridan
Hello,
I have a question, my 2012 F10 has options for connected drive but it never works, I paied my iPhone and enabled internet hotspot via bluetooth, when I press on ConnectedDrive it shows loading and after 5 minutes tells me is not possible and I have to call BMW, when I try to add my VIN in BMW Remote app it tells me the car is not supported.
S612A BMW Assist
S616A BMW Online
S6AAA BMW TeleServices S6ABA Control, Teleservices
No, can't be coded. If you want to add BMW Apps then a 9C FSC Code is needed and Coding for 6NR.
#444 ·
@shawnsheridan
Hello,
S612A BMW Assist
S616A BMW Online
hi too i would like to activate BMW online via hotspot. I have f11 of 2016 with nbt2
#433 ·
#439 ·
#442 · (Edited)
I have BMW F46 216d with EntryNav headunit, i use it in Russia.
My phone - Redmi Note 8t (android os).
I want to activate BMW Online and BMW Apps.
Is it possible in my car and headunit?
Сan anyone (or @shawnsheridan) give me advice how to do this?
m/m options:
610 Head Up Display
650 Cd Player
676 Hifi Loudspeaker System
698 Area-code 2
6AC Intelligent Emergency Call
6AE Teleservices
6FW Media
6UP Navigation Plus
#459 ·
No. BMW .bin UPD09032 is for Bluetooth Update. UPD03553 is custom .bin, with 3553 being last 4 of VIN. .bin File Names make no difference.
#464 ·
I recently got this update through a member who PMd me on here.
Has anyone else had an issue using an OBD2 Bluetooth scanner? Following this update I can no longer read error codes on my car except for one module... 63 Headunit, the module that was programmed.
I feel like during the process, that the remaining modules may have been excluded from the ECU list and I have no idea of how to get them back on.
#465 ·
Apps should have no affect whatsoever on fault code scanning.
And Scanner should be querying all system busses to pull fault codes, not using any predefined ECU List.
#476 ·
Hi guys,
I started to add the DAB+ function (europe no Sirius) to my entrynav2 by changing the antenna amplifier (placed on the trunk door n° 65209352603) and adding the cable (61126821855) from the yellow Head unit fakra to the new antenna amplifier. Now I have to activate the DAB+ function. I use BIMMERCODE. At the moment I managed to listen to only one radio station, can you help me (section 3002 HU I think please?
#477 ·
This has nothing to do with BMW Apps, which is the subject of this thread.
You should be VO Coding Head Unit for 654 DAB Tuner rather than trying to FDL Code it.
#481 ·
BMW Apps requires a 9C FSC Code and 6NR Coding. BMW AG however discontinued the ConnectedDrive App and replaced it with the myBMW App, so an older ConnectedDrive App would need to be on Phone and even then i am not sure it would work.
