1 - 5 of 5 Posts
My "Service Engine Soon" light came on and I dont have the proper tools to diagnose the problem (2nd week owning the car). Are there any VA/MD/WV 540 owners that have the engine diagnostic tool that could help me out? There's a 12 pack of your choice involved :thumbup: ... along with my gratitude.
Search, Read, THEN Ask
Welcome to the Fest!
Depending on the type of cluster on your car, "Service Engine Soon" usually refers to changing oil or general maintenence- Inspection I which is different from "Check Engine" which requires to read a code. If oil has been changed recently, it just means previous owner didn't
reset the light. There is a tip somewhere where you can reset that light by shorting two pins at the service connection in the engine bay. I believe pin 7 and 19? Here it is
Sometimes SES can also be caused by fuel related issues. Like a loose gas cap. One can try to disconnect the battery for about 5 mins and reconnect and it may go away.
If you live near an Autozone, you can try using their OBD scan tool. For long term, you should probably buy a scan tool as you'll need it for many things if you keep the car for some time. The most popular is Peake Research which sells for about $120-140.
You know, i did notice a hissing sound when i took off the gas cap, 15 min later the light came on.
If related to filling up gas. Go and re-tighten the gas cap. Usually after about a few days of driving, it may reset itself. Otherwise, try the battery trick. If light comes back on again after disconnecting the batter, get yourself a scan tool or go to a nearby autoparts store that offers free code readings.
1 - 5 of 5 Posts
