my car has a significantly lower idle in park and neutral approx.(400-500rpm) than in drive approx. (800). In Drive sometimes it gets unsteady, but never stalls.
P1250
P1622....im pretty sure these first 2 are the wheel speed sensors
P0150 Bank2 sensor1
P0505 IAC
P0173 Fuel Trim bank1
P0170 Fuel Trim Bank2
P1188 DTC
now i dont have a clue what DTC is and im assuming the fuel trims are clogged fuel injectors? so i put fuel injector cleaner in.
getting my car running right is my top priority right now. i have cleaned the IAC but the code still comes up for it.
Things i have cleaned/repaired:
-VCG
-cleaned maf
-cleaned IAC
-misc. vacuum leaks (it has been tested)
-replaced air filter
-cleaned throttle body
-replaced both intake boots
-spark plugs
-replaced both pre-cat o2's
Help would be greatly appreciated! thank you.
P1250
P0150 Bank2 sensor1
P0505 IAC
P1188 DTC
-VCG
-cleaned maf
-cleaned IAC
-spark plugs
