I have a 2012 X5 35i and 43,000 miles. About a week ago, anytime when I turn on the A/C on over 65f and also turn on the blower, the engine cooling fan runs high speed every 4 to 5 seconds. When I turn off the A/C and blower, the cooling fan stops. Everything runs fine if I set the A/C temperature is below 65f.
I tried to turn on the blower on without the A/C on and the cooling fan stills run high speed every 4 to 5 seconds. I tried the heater too. I get the same results. Is it caused by water pump and thermostat or any temperature censor? Anyone have the same problem?
