Looking for some help hopefully this forum can help me out. Searched as much as possible before making an account to post.
Recently purchased a 1999 e39 540i with leaking valve covers. Replaced to stop oil from getting on spark plugs. Reassembled, started car (it did start) and received an engine failsafe alarm. Turned the car off, investigated, and found I had not tightened a coil down all the way. Tightened the coil down tried to start it again without any success. The thermostat was pegged at red and the alarm was still there, so I went through the steps of checking EF1 through EF5 all of which were good. I also replaced the thermostat sensor which is still reading red. I checked the DME since I was not getting any codes to see if there was any damage to the board or the connections however I did not see anything.
Attempts so far:
-Unplugging battery for 15min
-Checking all fuses EF1-EF5 (replaced EF1 just to double check), glovebox, and trunk
-Replacing thermostat sensor(still not working)
-Unplugging MAF
-Unplugging crank position sensor
-Visual inspection of DME and connections (attached picture)
The coils are not firing, and the temp sensor is reading -128 degrees Celsius. Any input is appreciated.
Attempts so far:
-Unplugging MAF
