1 - 3 of 3 Posts
my engine idles slighlty higher than normalabout 1000rpm is the norm or is it a little high? how can i adjust this issue. another ? is i have trouble with my transmissin just 1st gear i was told that the synchro was going out or already is. it grinds when i try to shift into it unless i go to from 2nd to 1st and i'm at a complete stop. can any one help. thanks in advance.
did this just start, or are doing something different (like using the defroster??) that would bump up the idle??
same with the trans. just start?? getting worse?? pedal feel different?? longer pedal travel??
we could post the standard responses which may or may not send you on a wild goose chase which is why i posed these questions.
df
Another one, does the tranny have fluid? If so, is it old?
Are there any noises at idle in neutral with the clutch engaged?
Is the idle higher with the a/c on or off?
Sent from my Droid using BimmerApp
1 - 3 of 3 Posts
