1 - 5 of 5 Posts
I need a little help. i was driving the other day and all of a sudden i had an engine malfunction message on my screen, i did not get a pic of it because i left me cell at home. But it said drive moderately, it had no power and the engine quickly died. I towed it back to my house and now the car will not start. i have tried to jump the vehicle but it only clicks and will not turn over. I l;looked on the forum and it says it could be a fuel issue or spark plugs. but since the car will not start im leaning towards starter. looking forward to hearing some feed back.
thanks in advance,
Joe
Unlikely to be the starter - unless you burnt it out trying to restart.
Think about it, would a starter cause your engine to die?
Is it more likely that the repeated attempts to start have drained your battery?
Best thing to do would be to get a code reader and then give the codes which should be stored if you got a drive moderately fault that caused the engine to stall.
Same problem happen to me so i charged the battery back up and checked my alternator.It was bad so i had it rebuilt and went to oreilly's and pick up a new battery since the original battery was five years old. That should help you out.
Sounds like your alternator died and the repeated attempts to restart the vehicle drained the battery. good luck.
1 - 5 of 5 Posts
