So I tried getting feedback from a similar post with no luck so im starting my own to help get some help in my specific case. I've been having cooling system issues( leaking coolant temp sensor) its was leaking from o ring but recently stopped nd so did the crazy thermostat movement. But im about to do a cooling system overhaul anyways. I also have leaking vcg and vanos that are getting repaired at the same time(have been checking & topping off oil).
The car has been running fine up until lately the flickering red oil light and then at stops the dreaded *Stop! Engine oil pressure warning *.. I check oil level as it says when I turn off car but there's plenty and thermostat stays in the middle so no sign of overheating. So I took it home nd didn't drive the rest of that day. The next morning for work I start up car and no flickering or stop engine nonsense. So I drive to work. On my way everything running fine, that is until car warmed up enough to bring back the flickering oil light & then when it comes to a complete stop or rpms reach 1 the STOP engine oil pressure warning comes on.. If I continue to drive I get this burning oil rubberish smell coming threw the vents I think. I never drive to much after that cause I feel the difference. Like a big loss in power mostly in 2nd, 3rd nd 4th gear.. From what I read on similar issues on here it could be a couple things but since Ive got such a detailed diagnoses I wanna give you guys some pics nd my thoughts.
Im thinking Ccv failure since there's all this new oil residue all over the hoses ns wires behind nd under my upper intake boot.(1st. 2nd 3rd picture). My other thought I got from another person on here which sounds closest to my issue is radiator Thermostat which would probably explain the sudden stop in coolant leak nd gauge going crazy all of a sudden. Plus I just noticed today the bleed screw on the upper hose has coolant on it evidence of it leaking?. (Pic 4) im gonna order a oil pressure sensor nd oil filter housing cap since im replacing the gasket on it anyways.
I just really want someones feedback (preferably a forum God such as blubee or fudman) lol. But seriously anyones two cents would be GREATLY appreciated! I just love ny car nd don't got cash ti be blowing out engines.. Thanks in Advance!
