Hi,
Has anybody had a similar experience as below?
I have a 2004 330i ZHP. It has run beautifully for almost 10k miles. Just recently I started having some cold-start issues.
After starting the car in the morning, about 3-5 minutes or 1 mile into my drive:
Very oddly, it has never happened in the evening, when the car has been sitting for only 8-10 hours, it has only happened in the morning, when the car has been sitting for 11-14 hours.
I took it into the dealership. They saw the fault codes but had to ask BMW NA how to fix it. They replaced the DME (engine computer). This cleared the fault codes and I took the car home. Then it started happening again so it is now back in the shop! This time the "service engine soon" light came on and stayed on.
Supposedly my car already has some updated throttle body motor and wiring harness, from the factory, but they are considering replacing those. It sort of seems like they have no idea how to fix it but keep replacing parts hoping that will fix it.
Could this be a ZHP rough idle issue? Software issue? Please help!
Thanks.
- the yellow brake, DSC triangle and EML lights all come on,
- the rpm's start revving up and down between 800 and 1500 and
- the DSC starts cutting power and braking.
Thanks.
