Hi All,
My E70s electric fan appears to be inop, but it's not the fan itself. When I start the car, I don't get the 20-second fan run that I've seen is standard on the car. I recently had the fan out to replace the radiator (leaking) and a few hoses (soon to be leaking). Upon reinstall, I ran the car up to 97C as reported by the Torque app on my phone, and the fan never engaged. I wasn't sure of the operating temps so I didn't want to run the car any warmer than that.
The A/C has been out on the car for about a year now, and I hadn't been able to figure out why. It seems possible that the car won't run the AC because the radiator fan is not operating, which would mean the fan's not run for the past year. I've not once received an overheat warning on the dash.
I bought a new Genuine BMW fan and plugged it in - still no 20-second run up. I replaced the fan relay in the passenger's wheel well, and no fan action on either the old or new fans.
The only way I can get the fan to run is if I start the car, then plug in the fan connector. At that point, the fan will run full speed until I stop the engine - then it will not start again if I restart the vehicle. It will do this if I have the relay in place, or if I remove the relay from the circuit entirely.
I checked the signal wire and saw 100 hz of frequency. Does anyone know what the operating frequency for this wire is? Maybe that's my problem?
Pulled codes (no dash lights on) and got 2EFE - cooling fan, 2E83 coolant pump reduced power, 2E97 alternator, and 2DEB power management failure. This is a very odd set of codes - I can't imagine the water pump is failing if I have a functional fan that's not spinning - seems the car would spin it at full speed as I've seen posted on some comments about failing water pumps on the forums.
Really getting frustrated on this issue. Please help! I did throw my multimeter on the coolant temp sensor, and got no voltage or resistance (car switched off). Not sure if that's a valid test for this car, though - it's so incredibly dissimilar from my E46. Any and all help is appreciated.
