1 - 7 of 7 Posts
on my 01 Mroadster after coolant was drained and refilled. Autozone scanner did not work it kept getting "Link Error". Maybe coolant got onto the OS??? Any suggestions??? TIA
Wish I could help, but I have a similar problem with my 2000 M coupe. I had a CEL telling me my 02 sensor 1 - 3 pre-cat was bad. Changed all sensors now I have a CEL telling me 1 - 3 post cat is bad :dunno: When I reset the light doesn't go out, however when I start the car and drive the light is off...until I turn off the car and restart it again :mad:
Im here
Hey Ron, not to jack this thread but i got my peak tool today, there site shows a r5/srs-16 for 2001-2003 that is what i ordered, I got a r5/srs per reciept says 93-00 models?
is this the right one do you think, i do have the round connector under the hood and tool is round
19,585 Miles
I have the same one. It works on my car (used it last night since I had the drivers air bag out) but comes up with the flashing E (communication error) when you do a reset. I worked with Dan Peake on this but he never followed through.
Ron Stygar said:
Did you replace with BMW sensors?
Well, I have Bosch in the front, since Bosch was out of stock, and Siemens in the back (from Pelican) which were the same as the ones I took out.
My airbag light is also on. I tried to reset and got the "E" also, and Dan from Peake sent me a website to go to for add'l instructions, but that didn't help either.
http://www.peakeresearch.com/srstech.htm
Lights are still shining! However, the car drives just fine.
Discussion Starter · #7 ·
Here's the update.
I came by a BMW repair shop this morning and the mechanic there cleared the error after opened and closed the gas cap. I don't know how did that happen I haven't touched it for a week.
So, which Error Reader should I get?
1 - 7 of 7 Posts
