2009 535i xDrive; engine N54(B30)
When I accelerate from ~45 mph to just above 65mph (when entering onto a major highway), on many occasions there is engine shake. I believe it's engine shake (no shimmy of steering, etc.), almost like the engine has bad supports! (hard to explain) However, at other times there is no shake at all even going up to 85 mph or higher. The shaking is not violent or uncontrollable, but clearly this is not good.
I recently got the dreaded "low pressure fuel pump failure" message. Based on codes (using BMWhat), indication of fuel sensor failure and/or fuel pump failure. I have replaced the fuel sensor and the associated codes are not reappearing (after clears). Car generally is running fine if consistently below 55 mph and without hard acceleration.
Some background on car's maintenance:
Castrol synthetic oil changed 4k miles ago
Air filter changed 2 weeks ago
Using 92 or 93 octane gas; also, "Techron concentrate plus" just to clean-up any gunk
Tire pressure is checked and is holding fine
Tire has 80+% tread; was balanced 6 months ago
I am going to borrow (from Autozone) the "Actron CP9920A" and check the fuel pressure to see if that may be causing this ... I am hoping it's not the fuel pump that's bad. If so, I have to open up the fuel tank under the rear seat! PITA.
Next to do: change spark plugs, since I have no idea when the PO changed the spark plugs.
Any other thoughts?
On a separate, but unrelated note, I am getting "excessive battery discharge" message. The battery had drained down quite a bit (below 12V). I have since charged the battery (full, then trickle) and it's now fully charged (showing 12.7V not charging and 14.1V charging at idle). This issue seems be reported for this model without a clear solution? I have since shut down everything manually (even the AC or radio) before shutting down the car. I am also locking the car just to be sure all is quiet.
The message still appears occasionally, especially after the car is sitting idle overnight (so, something is still consuming ... "alive"?)
Note: the IBS is currently disconnected, as I want to observe the symptom/issue without having to deal with (potentially) faulty IBS circuitry.
Any other thoughts?
