While reading through the Online Manual I downloaded from the Owner Circle site, I found that it is not recommended to turn on the car and leave it running to warm it up. The manual recommends that you turn on the car then drive off at moderate speeds to warm up the engine.
That's all fine and good.....but what about those of us who live in cold weather areas where you have snow and ice built up and the temperature in the car is below freezing? Even if there isn't any snow or ice it's still pretty common to warm up the car before you drive off so that it's at least not blistering cold as you're driving. Will this really cause damage to the car?
By the way for those of you still waiting for your X3 on order (like myself) the Owners Circle web site finally posted the 2005 X3 manual. Not that it's much different from the 2004 but it's there if you need it.
