Hello,
I got the engine malfunction light and when I read the error codes I can see P0101 and P0112, looks like the MAF. I also see a glow plug error on glow plug 6 and when I read the engine coolant temp after a longer drive I see on 75 Degree Celsius. I think the thermostat needs to be changed since I read the temperature should be more around 88 Degree Celsius, is this correct? Is it necessary to also change the glow plug in that case? And can the P0101 and P0112 have anything to do with the faulty glow plug or should I look for something else, can I clean the MAF? The intake temperature shows -40 Fahrenheit in my OBD Reader, seems to be way off, or?
Car is a 2012 X5 Diesel with around 100tsd Miles.
- Juergen
- Juergen
