1 - 6 of 6 Posts
Hi today I tried to flash with esys 3.27 and 59.0 in NBT psdzdata
It turns out that when I try to create svt target where i -step shipm is f20-11-07-504 and i -step and select target f20-16-07-501 complete flash to give the calculate button I get the following error message:
Error psdz
Generating target svt With complete flash strategy and integration level " f020-16-07-501 " ( target) and " f020-11-07-504 " ( shipment ) failed . ( C324 )
KIS error: Die werksverbauung an der Diagnoseadresse 0x67 enthält mehrere 100 % -BNTN ( 0800000ESE000005 , 0100000B3E000002,0600000F47000001 ) . ( 1283 )
My car is a BMW F20
i-step (current ): f020-16-03-504
i-step ( last):f020-16-03-504
i-step ( shipment): f020-11-07-501
Any solution to this?
Thank you
Premium Member
Issue is ZBE2 and FA Date related.
Discussion Starter #3 (Edited)
Hello is it and what was wrong with the car is that had the FA code 663 and this prevented svt_soll generate the file.
On the other hand I now appear different ECU , a single with black lines , others only with blue lines ( as NBT ) and other blue and red with black lines . I understand that only ECU have red lines are flashing ?
In case I NBT is blue , to make flash debere select blflash , swdeplay , cddeplay and ibadeplay but as a retrofit NBT I enter the vin number of the donor? or frame read out fa vin and give the button vin read like the rest of the modules ?
Thank you
- Anyone can help, as i m trying to flash my ZGW on the bench, but also show this
Hello!
I understood it right, you want to flash a NBT and you have a shipment i-level F020-11-07-504? In that case your NBT should be retroffited. You must get an error - the NBT never existed in i-level 11-07-504 so your calculation will have faults. You have to choose a shipment i-level where the NBT was built in in a F20/F30.
The picture from the ZGW flash error wasn't readable (okay, not on my PC).
CU Oliver
1 - 6 of 6 Posts
