21 - 40 of 83 Posts
hello
now this error
"E-sys 3.27.1 and full psdzdata 57.0" is not compatable. I would use older E-Sys 3.24.3 or update PSdZData to latest 62.1.
no not same no i-staep & calculate funcation not highlight
thanks
I have no idea what it is your are saying, but E-Sys 3.27.1 and 61.5 PSdZData work perfectly fine together for flashing.
hello thanks for help now everthing ok in 3.27.1 & pz data 62.1 , but in tal calualtion same error == fem_body 1608
thanks
Are you using E-Sys Launcher or E-Sys Plus for Flashing? If so, don't. Use E-Sys direct. And make sure you choose correct E-Sys Target Connection.
hello
use e-sys 3.27.1 direct & connection both try via vin & via getway , svt calculation ok but error in tal , car new gt series new 2015
thanks
thanks
No one can help you when you post minimal information. "error in tal" is meaningless.
After cic retrofit i tried active navi intel stwpatherv2 way i tried flash hu_cic with last psdzdata 62.5 but when i tried tal calculation got warning '1 WARNING events during TAL generation . (383)' And then when last step of flash ,start TA execution .it stoped and got 'mulf-36 exception code =49184 MODE_CHANGE PARAMETER doesnt map to and ..
What is the problem
My donor car for cic is build year 2012 .so for intel navi activation patch is it need cic flash with new firmware or not i dont know version of cic now .how can i check firmware version of hu_cic .if firmware is c16 may not necessary flash.
I am having the similar problem.
DetailInfo must not be null for ECU ECUId:FEM_BODY_0x40 [1608]
com.bmw.esys.domain.psdz.PsdzException: Generating TAL failed! [C041]
at com.bmw.esys.domain.psdz.PsdzLogic.generateTAL(PsdzLogic.java:498)
at com.bmw.esys.domain.psdz.Psdz.generateTAL(Psdz.java:694)
at com.bmw.esys.domain.tal.TalLogic.generateTal(TalLogic.java:225)
at com.bmw.esys.gui.tal.TalCalculationController.generateTal(TalCalculationController.java:340)
at com.bmw.esys.gui.tal.TalCalculationControlsView$TalPanel$GenerateTalAction.doActionPerformed(TalCalculationControlsView.java:509)
at com.bmw.esys.gui.AbstractView$AbstractGuiProgressAction$1.init(AbstractView.java:425)
at com.bmw.esys.gui.component.DialogProgress$2.construct(DialogProgress.java:152)
at com.bmw.esys.gui.component.SwingWorker$2.run(SwingWorker.java:145)
at java.lang.Thread.run(Thread.java:745)
Caused by: DetailInfo must not be null for ECU ECUId:FEM_BODY_0x40
Timestamp: Thu May 21 10:40:16 CEST 2020
Class: com.bmw.psdz.tal.TALGenerator
ExecutionContext={category=TAL, ecuid=(FEM_BODY,0x40)}
at com.bmw.psdz.tal.TALGenerator.setBN2000IdentData(TALGenerator.java:791)
at com.bmw.psdz.tal.TALGenerator.createTAL(TALGenerator.java:387)
at com.bmw.psdz.tal.TALGenerator.generateTAL(TALGenerator.java:710)
at com.bmw.psdz.facade.LogicBF.generateTAL_aroundBody24(LogicBF.java:219)
at com.bmw.psdz.facade.LogicBF.generateTAL_aroundBody25$advice(LogicBF.java:84)
at com.bmw.psdz.facade.LogicBF.generateTAL(LogicBF.java:1)
at com.bmw.esys.domain.psdz.PsdzLogic.generateTAL(PsdzLogic.java:492)
... 8 more
I tried:
This error is normally VIN issue. You must check the box for Read VIN from FA, then press the read FA Button, then execute the Flash TAL.
No luck.
E-sys v 3.32.1
Any Guidance would be greatly appreciated.
v.4.22.14_PSdZData_Full
... 8 more
I tried:
No luck.
E-sys v 3.32.1
Do this exactly:
1) Read FA
2) Select Read VIN our of FA & "Read VIN"
3) Then do all of the ECU Selects - blflash...
4) Do the Check Software
5) Then select the "Read VIN out of FA" which greys out the "Enter VIN"
6) Then do the Start...
Hello,
I am not sure how to follow the instructions,
I tried the use the C:\Data\SVT\SVT_soll.xml file but I have problems. the software states the following: ecuStatus, ecuDetails, ecuBusCOnnection entries are missing on the SVT, Could this cause the problems with the calculation as well?
I was trying to follow the guide Upgrading ECU***8217;s on BMW F11 520d in order to update all the modules to the latest. I manage to read the FA, created the SVT_ist and the SVT_soll but failed on the calculation.
I have tried to follow your instructions but I got stuck
1) Read FA
In comfort mode?
In Expert Mode??
I have no idea where this is done.
I am sorry, but I am quite inexperienced on this.
Hello,
I was trying to follow the guide Upgrading ECU's on BMW F11 520d in order to update all the modules to the latest. I manage to read the FA, created the SVT_ist and the SVT_soll but failed on the calculation.
1) Read FA
In comfort mode?
In Expert Mode??
I replied to your PM.
Shawn
I would like to thank you for your altruistic help. It is awesome to have experienced members whom are willing to help inexperienced members, because they just want to help.
This saturday I will be flashing the car with the files you helped me get today.
I look forward to return the favor one day.
Hi Guys
i want to flash my NBT Evo from ID4 to ID6. Do you have any tutorial?
I have ESYS 3.28.1 or ESYS 3.33.4 with v.4.23.12_PSdZData_Full
which one to use?
some links or documents how to do it?
While possible, it is not advisable. ID4 Hardware has 2 Gb of Ram. ID5/6 has 4 Gb. If you flash ID4 Hardware with ID5/6 Firmware, it will run slow, and suffer frequent reboots as it does not have enough memory. You will also need new ID5/6 Map FSC Code and unless car has a functional ATM module, you will loose all Telematics (e.g. RTTI).
21 - 40 of 83 Posts
