1 - 8 of 8 Posts
I was having issue with the navigation option not showing up on idrive as well as it not sending navigation to the cluster after a black cluster upgrade.
I then redid a code after adding 609 to my FA. Now I see this as my main screen. Everything as in the Sub menus shows up fine in full screen. Reverse cam etc all seems
To work fine . But navigation is not as it ask me
To enter code to enable navigation. Any ideas what I did wrongly? It’s a retrofitted Evo unit.
Discussion Starter #4
Set it to id6 lite and it***8217;s looks fine now. However when I start navigation, it ask me
To insert USB with correct activation to start navigation. I will try to insert a USB with my update Map to see if it works.
Thanks all!
Discussion Starter #5
Navigation still a no go. I tried using last year map but it still prompted me to insert a map with a valid activation code. Can I get such a map with activation code? I used to be able to just update map without fsc code. It seems like all my fsc cert are in place with no errors.
Hello!
The Evo is retrofitted and due to this the FSC are also not oirginal. Use a new FSC set for this unit. If you updated the Evo to an i-level 18-11-5xx you cannot do it via USB-stick. In that case you have to use your enet cable and special tools like femtoevo or featureinstaller with the correct files (which you have to buy).
CU Oliver
1 - 8 of 8 Posts
