Exactly how does launch control work?
5066 Views 4 Replies 3 Participants Last post by  exsilio
As much details as possible please. Is it some sorta button that you tap that automatically launches your car? Also, is there a neutral position on SMG? Can you still rev up and drop it into 1st?
1 - 5 of 5 Posts
Here are the instructions for the LC. Have fun.
* Disengage the DSC
* Place transmission in Sequential mode 6 (it won't go into S6 unless DSC is disengaged)
* Push shift stick forward (- symbol)
* Car will rev to 1500 RPM
* When you are ready to launch, release shift stick and hold on to your @!#$ cheeks.
The first time I did it I spun the tires pretty good, not intentionally of course, but the next two times were smooth. Even at only 1500 RPM it’s quite a boost off the line. Enjoy.
See less See more
* Disengage the DSC
The first time I did it I spun the tires pretty good, not intentionally of course, but the next two times were smooth. Even at only 1500 RPM it's quite a boost off the line. Enjoy.
See less See more
you have to mash the throttle after the stick is forward too, right?
d'oh! good call man! I forgot...heh heh
Okay revised steps :)
* Disengage the DSC
* Push shift stick forward (- symbol) and hold there
* Depress accelerator pedal all the way down (yes floor it)
See less See more
1 - 5 of 5 Posts
