1 - 5 of 5 Posts
I cant remember if i posted this issue on this forum so I appologise in advance if i have..i bought the 2011 550 manual and due to DMV taking forever to process my registration, i used that time to do some preventive maintenance. Oil, plugs and OEM CCV hoses. The engine ran much better and idle is smooth as glass. Shortly after, i noticed what sounded like a belt squeek so i ordered belts and tensioner. When i pulled off the bottom engine covers, i found the noise was coming from the back of the engine. My son did some research and pulled off the oil cap, with quite a bit of effort, and the noise went away. What could cause excessive crankcase vacume? I believe the noise i was hearing is air being sucked into..any ideas of the cause of this issue? After some more research, i found that the oil separators are located inside the valve covers. I am hoping for some feedback from you all to see if r here could be other causes of excessive crankcase vacume i am not throwing any codes at least not on Carley or protool. I just want to explore any other possible ideas youall might have as the cause. Thanks
Sent from my SM-G965U1 using Tapatalk
I make bowling balls for a living
Slap a valve cover on it. The diaphragm is torn.
FYI there are aftermarket places that sell just the diaphragms. I’ve never done just the diaphragm on N55 but I have on a few N52s and N20s
Discussion Starter · #3 ·
This is an N63. I have the parts to do the job, im just looking for ideas on what else could be causing this issue before i stare taking it apart. This is my first turbo and direct injection engine so im trying ro get as much info as possible
If it’s N63 then you don’t need valve covers, you need the little boxes bolted to the insides. The vent valves/oil separators are available separately and not part of the actual cover.
Also make sure to replace the vent hoses
Discussion Starter · #5 ·
Thanks. I already replaced the vent hoses and thats how i discovered this issue. I just received the units for inside the valve covers. Im just waiting on the tool i ordered for removing the injectors i also got new teflon seals for the injectors. Thanks for the reply
1 - 5 of 5 Posts
