I am trying to gain a better understanding of the readings I am seeing on my BlueDriver OBD2 scanner. I am hoping experts on this forum can shed some light on how to interpret these readings.
I read through the Diesel Emission Control System section (Page 113) in the attached PDF.
To keep this post short, I am also attaching the schematic on Pages 109-110. The temp. sensors I am enquiring about are #17, 19 and 28, highlighted with a solid red square.
My scanner reads three temperatures under the Exhaust Gas Temperature (EGT) category (see attached screenshot):
Regarding ECT, as part of routine maintenance, around 90,000 miles, I changed the water pump and coolant thermostat . . . coolant temperature jumped from 82 °C to 88 °C . . . regardless of ambient temperature, coolant temperature holds tight between 87/88 °C (occasional very brief excursions to 90/91 °C) . . . except once when the ambient temp was 105+ °F and driving curvy/hilly roads, 30-40 mph . . . ECT showed 103 °C, did not throw any error codes.
To summarize - can I used these temp. sensor readings to detect a regen event?
Second, will DPF pressure delta readings tell me if the DPF is getting plugged up (regen not happening) and DPF is on its way its way out? What is the max kPa permitted before error codes are generated?
Thanks.
PS: My X5 - E70, 35d, 2011MY, June 2010 build, ~106,000+ miles
- Bank 1, Sensor 1 (EGT11)
- Bank 1, Sensor 2 (EGT12)
- Bank 1, Sensor 3 (EGT13)
- Do sensors #19 (pre DOC), #17 (pre DPF) and #28 (pre SCR) correspond to EGT13, EGT12 and EGT11 respectively on the BlueDriver OBD2 (see exhaust gas screenshot) OR did I get them backwards?
- As the exhaust flows out across DOC/DPF and SCR, am I correct in assuming it gets cooler? i.e. #19 is the hottest, #28 the coolest and #17 is in between? Don't know if the DOC reactions are net endothermic or exothermic.
- When DPF regen happens should I see #17 exceeding 600 °C? During DPF regen should #19 and #28 also get very hot - exceed 500 °C range?
- Today went for a hike in the Berkeley hills . . . driving uphill to the parking lot got the sensors to exceed 600 °C (see attached sample screen shots) . . . not sure if this was a regen event OR simply due to the extra load going uphill.
- What are the normal values (non regen) for these sensors? ~240 °C?
- Scanner also reads the delta pressure across the DPF, see attached screen shot. What is the typical range for this pressure delta?
- Post DPF regen, logic says this delta should be less (less embedded soot, less resistance to flow) . . . not sure if this reduced delta is orders of magnitude smaller (therefore not detectable) than what DPF sees with varying load conditions - noticed, at idle, the pressure delta is less than 1 kPa, going uphill it gets close to 10 kPa (1.5 psi).
Thanks.
