F10 Coding questions
17K views 30 replies 15 participants last post by  mikedensem
BTW, I had tested, HELLIGKEIT_DRL it only change the brightness when angel eye act as DRL (Day Running Light) ,the default setting is 100% already.
What I want to test is, if the angel eye brightness can by changed independently when it act as small light without headlight on. Any idea?
Thanks BMW530xdrive,
Not sure how people call it, the F10 LCI head light, above its angel eye , there is a thing white bright line (engel eye brow maybe ?)
my question is: is there an independent brightness setting in Code for that one?
Thanks for any advise in advance!
Hello!
To activate the rear lights you need only the code FRM/DRL_MODUS set to TFL_S - that's all.
The codes for a F20/F30 are different due to the reason that these cars don't have a FRM modul. You can also code the FRM/3060/U_EFF_POL to 100%. With this coding the coronar lights will not dimmed while driving with xenon lights on. It looks really better in the night (not allowed in some countries - f.e. here in Germany - but after several years with this coding I got no problems with the blue race control).
Without the SA 302 (alarm system) you will not be able to active the acoustical lock confirm!
CU Oliver
Just verified FRM/3060/U_EFF_POL, it will adjust the angel eye brightness disregard if the headlight on or not.
Is there a parameter to adjust angel eye brightness when it act as small light without headlight on?
