F10 - Daytime instrument cluster no light after coding
29K views 75 replies 22 participants last post by  phenom3
#1 ·
Hi Folks,
Thanks to the forum and help, I did some coding on my F10 yesterday night. Was able to complete coding on Navigation Disclaimer, Remote Trunk close, TPMS showing pressure etc. Still haven't got mirrors folding on comfort access (some issue but did not have time to diagnose).
However - a strange thing happened - my instrument cluster does not have the white backlight during the day. It does have the orange light during night. I am sure I did not touch anything regarding this during coding.
Any clues/direction ? Anyone face this before ?
#67 ·
Will ISTA inform if any changes had been made?
And if the dealership come back and say it had tampered with would they void the entire warranty or just that part?
Sorry for the tonne of questions
I told you already what I think. I am not going to speculate anymore, but they could not void warranty on entire car. 99% chance is they will just service the car, like any other service work.
#7 · (Edited)
Change werte to 32, not 0A. Do you have an LCI? Maybe they changed something... I distinctly remember coding one of the modules, and all of a sudden getting the white display at night (it never changed orange), without me actually changing this setting. I went to the werte value and changed to 32 and it started automatically changing again.
#12 ·
Similar Issue
Hey all, newbie on here and this is my first post, I had my car coded yesterday and noticed yesterday evening that I had the same issue, the car display is not lighting up. None of the setting for this were changed except to add the feature of having mph displayed in the computer.
Anyway managed to rectify this issue? Any help much appreciated thanks :thumbup:
#15 ·
Hi there,
my fellow coder tried to change the settings from white/orange to white only. It seems he could only change the backlight from "orange" to "grau". The only change I discovered is that the lines showing up below the instruments are grey instead of orange. The rest is still orange when driving in dark.
Does anyone know how to make my instr. cluster showing only white light ?
could it be possible that it is due to my car being built 9/2014 and that BMW changed/removed some codes?
Thanks in advance
#46 ·
I am not aware of it being an issue for anyone else but you an OP, and he never updated us. Bottom line is if Coding caused it, and Coding was reset, it would be back to normal. You should also VO Code Head Unit. The two ECU's are interwoven.
#52 ·
another thing i was just thinking
car is a LCI m135i
when i launch Esys premium launcher what should i select for car series?
premium launcher F020
esys F020
is that correct?
E-Sys Launcher Car Series needs to be set to exactly what car is (e.g. F020, F021, F022, etc.). E-Sys Connection Target needs to be set to F020. This though is not cause of your issue.
#72 ·
Hi Shawn
I also have the 'sudden no daylight instrument cluster lights' issue. Just yesterday they stopped working for no reason, and I have not coded anything for weeks.
I have this morning tried the 'changing werte to 32' and also the 'KOMBI_BACKLIGHT_HIGH' suggestions here, with no luck.
I am not sure how to do the 'VO Right click to reset it' you have suggested, Can you please give me a bit more info on VO things.
This is for a Mini Clubman F54, which uses the F056 software connection in the coding software, which seems to work fine.
P.S, some months ago I did code to try and have white instruments even at night, but never got it to work. I think it was only the KOMBI_DIM_NACHT_EIN werte change, which has since been at the default OA.
I just don't know how it could suddenly just not work.......
Any help would be appreciated.
Matt
