Status
Not open for further replies.
F10 Headlight Module programming
1 reading
51K views 61 replies 34 participants last post by  Adalbert_77
Can someone help me how to program my headlight, I replaced the module on ISTA, but need to program the module, thank you
Program whole car with ISTA+ or Flash module with E-Sys and PSdZData Full.
Save
Hi Shawn, I replaced both headlight with the modules it came with. It is used one. now I see only low beams work. Nothing else. Could you guide me to recode and then to code to make it work. Car 2015 bmw 435i f32. Please help
I have no guide for this. If you replaced any ECU's, you need to inject CAFD and VO Code it, and then initialize the lights in ISTA.
Save
Hi Shawn. I have the sĂ­milar problem: replaced TMS modules amd now vertical aim is all over the place. Passenger side DRL are not workimg.
When you say "inject CAFD" : which software are you referring to? E-Sys?
I own Bimmer Utility but think i need a newer E-Sys like 3.30 with the psdzdata full. All E-Sys I have found are full of viruses.
Can you tell me how to get a working E-Sys?
Yes, E-Sys. PM sent.
Save
Hi Shawn, My bmw car is 9 pin headlights. But the mechanic replaced with 8 pin. Do you think it can work. Also drl s sometimes turns on by itsrlf sbd then as we touch the car yo open it closes. The low beam only works. Can you please suggest. Thanks.
Sorry, I have no idea at all.
Save
Save
@shawnsheridan , you seem like a nice person helping a lot of newbs like myself out. Can you assist me in obtaining a virus free e-sys ( I have INSTA up and running) to help with exactly what everyone in this thread is going through?
Many thanks to you.
Cheers!
PM sent.
Save
Thanks. /bow
For a new TMS, do I need to flash or code? PSdZData FULL or LITE required? Appreciate your patience.
Can't predict. 1st try coding with LITE and then if you have to flash, flash it with FULL.
  • Like
Reactions: tonyneill
Save
Save
Save
Save
Save
Status
You have insufficient privileges to reply here.
