1 - 20 of 25 Posts
· Registered
Hi all I flashed all my modules successfully through esys but the IHKA module came up with completed with warning. I have since noticed my DL side won’t blow hot air now. I have tried reflashing and no success the software parts were successful now I’m at a loss and the module shows up with no errors in ista.
[IHKA - 78] possible timing violation detected during execution of service TD - TransferData [WARN]
MCDDiagService<id=3800, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUFlashBL, service=TD - TransferData, description=warning: timing violation (no error), link=IHKA_78_ETHERNET> [DIAGSERVICE]
[IHKA - 78 - btld_00002788-002_016_001] Transaction type: blFlash; Message: 100% progress on ECUId:IHKA_0x78 [100% of btld_00002788-002_016_001] [TRANSACTION]
[IHKA - 78 - btld_00002788-002_016_001] Transaction type: blFlash; Message: TA finished [TRANSACTION]
and the errors now showing on BimmerLink
Font Screenshot Software Multimedia Rectangle
· Registered
F30 335xi 2013
Right click on IHKA and button CODE. Everything is ok with IHKA on picture. After you code IHKA go with ISTA and clean error. If you see that AC button flashing wait 1 min til ihka initialisiert
· Registered
Discussion Starter · #17 ·
Can you explain how it relates to the flashing issue and resolves it, just so I understand. Was I meant to do the Code button for each of the ecus once they were flashed?
· Registered
Discussion Starter · #20 ·
Looks like some but no luck on this one, no errors showing in Ista or bimmerlink (where they showed before) Heat is minimal and blower is lower than passenger side even when on full. Yet ac aspects work fine. Passage will crank the heat and blow strong but not drivers, do I try and get psdz .39 full and do another reflash of all
1 - 20 of 25 Posts
