Hello everyone,
I have F11 535d, 2011 which is European version with bi-turbo and 313 hp. The vehicule has 112500km. While I was driving other day on the motorway there was suddenly yellow engine light illuminated. :yikes:
I have my WIFI OBD2 scanner which I plugged to check the code, because car did not gave me any messages on "idrive".
The fault code was P115D. I could find on the internet that the code means: The diagnostic function compares the calculated air mass with the measured air mass.
I have first cleaned my air filter which is really dirty and to be replaced. it is already fourth year.
I have cleared the code with my iPhone application but after some driving it would come back.
Finally today I have removed my Mass Air Flow sensor which is found on the top of the engine. You can see it once the engine cover is removed. It is located downstream of the air filter. I think it can be removed with ratchet and T25 or T30 bit.
I have cleaned the MAF sensor with my uncle's home made vodka.:rofl: I am sorry I did not have any isopropyl alcohol, but this one served very well.
Once I have plugged the sensor and re-bolted everything back, I have started the engine and the yellow engine light just disappeared. :thumbup:
I have rechecked with my iPhone app to see if there is any active fault code ant there was just the same code stored but not active like.
I have wrote this guide to help other people if they will have this P115D fault code.
I hope I have correctly uploaded some photos to see the thing clearer.
