F15 coding
98K views 373 replies 97 participants last post by  Carnepo
#1 ·
Hi
Has anyone tried to code an F15 yet using E-Sys? There is a thread in the coding forum reporting possible difficulties in doing this (Ethernet issues), but thought worth posting in here also in case anyone else has tried and can feed back results.
#3 ·
Awesome. Let me know how you get on. As you will see from the thread in the coding section ("Ethernet error") I have not been able to even get a proper connection. Keen to know if others with an F15 can successfully connect and read the VCM/code. That way ill know if a problem with F15 in general or just mine! Thanks.
#6 ·
Hi,
Just wondering if anyone knows technically what is included in the optional ConnectedDrive services package (ÂŁ230 option including Information Plus and Remote services) ? In other words what is the difference between a car with it and without it ?
I assume this to be the enablement or inclusion of a module and thus something that in theory could be added via a software update ?
Steven
#13 ·
Is there anyone around Northbrook IL who can help with coding? A shop or a fellow BMW owner?
I helped so many Audi people with coding using VAG tool in the past and BMW coding seems to be fairly complicated compared to Audis.
See my coding thread: http://f15.bimmerpost.com/forums/showthread.php?t=1033991. If you get the required files and ENET cable, I can teach and help you remotely. I've already helped out a few members :).
#17 ·
No Listing in Esys
I have just got my 2014 F15 and tried to connect to it using Esys and Failed.
I have changed the Settings as per instructions ie RAM set to 1024 and unchecked Update VCM after TAL Execution and also Update MSM after TAL execution, When I start Esys I do not get ANY listing of chassis Types at all even though it shows my VIN No, Does anybody have any ideas please?
It connected to my X3 with no problems, Does it mean a re install ?
:mad:
#18 ·
:mad:
What version of PSDZData files are you running? Do you have them installed in the correct location?
#19 ·
Hi Many thanks, I have managed to sort it, there was a corrupt file in PSDZdata folder reinstalled PSDZdata and all ok.
I have managed to code some but the ones I really wanted to code I can't ie
Emergency stop flashing brake lights and Changing number of Blinking turn signals, the LceMaster module is not present on my motor
#20 · (Edited)
because they are all located in BDC_Body:
BLINKZYKLEN_ANZAHL_TIPP > new value is werte = X-1, default is werte = 02. Change the triple blinker blinks to any amount. (Value is XX + 1).
ESS_AKTIVIERBARER_AUSGANG > new value is bremslicht, default is blinkendflachenvergroesserung. Change Emergency brake light from Inner Brake Lights to Flashing Lights.
ESS_AKTIVIERUNG_GESCHW > new value is User Value, default is werte=02 (5 km/h). Threshold Speed for Activating Emergency brake light
#26 ·
No, there is no way to do this. @shawnsheridan confirmed this a while back via coding. I looked it up myself and found the code as well.
HU_NBT > ENT_MC_VIDEO_SUPPORT > change nicht aktiv to aktiv.
It enables MC Video playback and saving of videos to internal HD, however it is confirmed to not work recently in the F30 forums. You can try your luck, though if you want.
