281 - 300 of 374 Posts
I wanted to code my car again this weekend and found that I don't have CAS module. I have a feeling I had this issue before, but can't remember what exactly it was. Maybe it is just a feeling :)
Does anyone know why and how to solve it?
If you are referring to an F10, like in your profile, then that vehicle may have a CAS module; though, ECU's just do not disappear.
If you are referring to an F15, like this thread, then CAS functions are in BDC_Body.
Anyone on here code 100% Corona Lights w/ Headlights on for Anti-Dazzle?
I forgot where I saw it:
PHP:
<cafd id="000024C3" name="FLE_02" author="Almaretto">
	[CODE]
			<group id="3004">
				<function start="10" end="19" mask="11111111b">01, 01, 0A, 01, 01, 01, 01, 01, 01, 0B</function>
				<function start="20" end="29" mask="11111111b">01, 01, 0A, 01, 01, 01, 01, 01, 01, 0B</function>
				<function start="30" end="39" mask="11111111b">01, 01, 0A, 01, 01, 01, 01, 01, 01, 0B</function>
			</group>
            	 [/CODE]
I've ordered my cable and want to start coding on my 2017 X5 40e. Can someone send me the links for the latest ESYS and psdzdata files? (Also if the E-Sys launcher is useful, a link for that as well..)
If you want to only VO code, you will need E-sys and Psdzdata. If you also want to FDL code, you will need Launcher for token and CAFD mapping. PM Sent.
Hello All,
Wanted to ask coding experts if there is a way to disable alarm from going off if there is something plugged in to OBD port when locking the car. Basically I have an Automatic OBD2 adapter, and when I lock my car the alarm goes off in about 2-5 seconds. Reading other places I see that this was an added programmed feature, so I`m hoping it can be coded off. Anyone knows ? Would really appreciate any feedback!
