F15 coding
1 reading
98K views 373 replies 97 participants last post by  Carnepo
#1 ·
Hi
Has anyone tried to code an F15 yet using E-Sys? There is a thread in the coding forum reporting possible difficulties in doing this (Ethernet issues), but thought worth posting in here also in case anyone else has tried and can feed back results.
#103 ·
Thanks for the replies, I still feel that theres perhaps an alignment issue or even air pressure I'm going to speak with service advisor nevertheless :tsk:
#105 ·
Hey, I got a new F15 m50d with fresh software update and i need the newest E-sys, psdz-data (don't know which one i need) (and Launcher?). Can anyone send me a link (pm)?
Kind regards from Germany,
Julian
PM sent.
#106 ·
Sos...
Hi Guys,
I have 2015 X5 35d with fresh firmware from dealer.
I need help. I accidently hit code item under ECU in Esys.. and it reset a lot of things.
One thing I lost is LED mood lighting. Anyone know how to get it back?
Also, can you send me link for latest E-sys and psdzdata files?
Thanks in advance.
#107 ·
Hi Guys,
Thanks in advance.
Code is no problem, and mood lighting will return on its own.
PM sent.
#120 ·
I too am looking for the link to E-sys and psdz-data as well as the tokenmaster app Can someone help?
I have the US version F15 35D built 6/2015.
Thank you in advance.
PM sent.
#124 ·
Hi,
I was attempting to read the ECU to back up the factory settings. Established the connection OK, but reading coding data of the CAFD files resulted in 25 errors. Only 6 CAFD files are saved in the data\caf folder. I'm running 54.1 psdzdata, e-sys 3.26.1 and launcher 1.0.7. Any help appreciated.
You must update,
PM sent.
#133 ·
#137 ·
Does anyone in the SF Bay Area know how to code? I would pay.
Also, is there anyway coding can solve the following:
1) DLR Currently does not turn on when unlocking doors via KeyFob in the day time (I have the lighting package, if that matters)
2) Auto Start/Stop enabled in Sports Mode. I ALWAYS drive in "Manual" mode. I would like auto start to be enabled when I move the shifter to the Right to "D".
#141 ·
Not possible. 606 Business Nav means you have ENTRYNAV Head Unit (forget fact that CAFD shows NBT in name) and Video is only possible on actual NBT Head Unit.
#150 ·
#151 ·
Hi Shawn
I just picked up a 2016 435 GC and a 2016 X5 X drive 35. My last cars were 2013 335i and 2013 AH5. I did some coding successfully on those, but havent touched or kept up with anything since I got my previous cars how I wanted them.
I have the enet cable, and old versions of the software. Could you send me a PM on what I need to code the new vehicles. If there is a link to the latest sheets for those two vehicles you have that would be awesome too.
thanks
