F15 coding
98K views 373 replies 97 participants last post by  Carnepo
#1 ·
Hi
Has anyone tried to code an F15 yet using E-Sys? There is a thread in the coding forum reporting possible difficulties in doing this (Ethernet issues), but thought worth posting in here also in case anyone else has tried and can feed back results.
#269 ·
Hi guys Also i have bmw ista and ista-p which is better for deep rooted coding the esys software or ista-p
Also is it possible to add factorry cameras front and rear to my bmw x5 f15 2015 it has no front or rear cams but iwas wondering if wiring loom was there and can buy cameras and code them in
It is full m sport spec with full pro navigation and all the other toys just no cams front and rear but has pdc.
Thnaks guys
#270 ·
ISTA is for diagnostics with ENET or ICOM as well as programming with ICOM. ISTA-P with ENET or ICOM is for programming. E-sys is for coding.
To add cameras, it is possible, but you would need a number of things. There are both OEM or non-OEM solutions. You will likely need wiring, cameras, iCAM ECU, possibly PMA_PDC ECU, and center console switches.
#277 ·
Hi Guys, my 2016 X5 has Driver assist plus and I would like to activate speed limit information on the HUD, I have activated the menu via coding and subsequently activated the option in the setting menu of the car. however I still don't get any limit information in the HUD. Could you please tell me if I need to activate something else via coding? Thanks.
#280 ·
Our F15 had a software update at the dealer last week, so I needed to re-do some of the coding. Everything worked ok, except for updating the number of blinks when I tap the turn signal stalk.
I have used BLINKZYKLEN_ANZAHL_TIPP off of the coding cheat sheet to adjust this in the past, but it no longer seems to have any effect. I did notice that the default value was werte=00 after the latest update, and in the past it had always been werte=02 as default.
Has anyone else noticed this on the latest software version?
Thanks.
#281 ·
I wanted to code my car again this weekend and found that I don't have CAS module. I have a feeling I had this issue before, but can't remember what exactly it was. Maybe it is just a feeling :)
Does anyone know why and how to solve it?
#287 ·
I forgot where I saw it:
PHP:
<cafd id="000024C3" name="FLE_02" author="Almaretto">
	[CODE]
			<group id="3004">
				<function start="10" end="19" mask="11111111b">01, 01, 0A, 01, 01, 01, 01, 01, 01, 0B</function>
				<function start="20" end="29" mask="11111111b">01, 01, 0A, 01, 01, 01, 01, 01, 01, 0B</function>
				<function start="30" end="39" mask="11111111b">01, 01, 0A, 01, 01, 01, 01, 01, 01, 0B</function>
			</group>
            	 [/CODE]
#300 ·
Hello All,
Wanted to ask coding experts if there is a way to disable alarm from going off if there is something plugged in to OBD port when locking the car. Basically I have an Automatic OBD2 adapter, and when I lock my car the alarm goes off in about 2-5 seconds. Reading other places I see that this was an added programmed feature, so I`m hoping it can be coded off. Anyone knows ? Would really appreciate any feedback!
#302 ·
Hi Guys, I was doing some coding on the weekend and my curiosity got the better of me in regards to VO coding and I tried to add 8TH. After not noticing any change I went and removed it and now I don't have CAFD in KAFAS2 and my lane departure and pedestrian avoidance have stopped working. Any help would be greatly appreciated.
#311 ·
You must use E-Sys Launcher to Open E-Sys, and you must have correct both E-Sys Launcher Car Series and E-Sys Connection Target specified.
#314 ·
Question on enhanced blue tooth coding, I would like to have visual for text message. I***8217;ve looked through a lot of information but I***8217;m still a little confused. I have a 2014 X5 and 2015 X5.
When I do a vin decode (internet) they both do not show 6NH or 6NS in the options.
but I do have the ability to use functions as indicated by 6NH blue tooth audio streaming etc.
Coding steps call for deleting the 6NH and adding 6NS, if the 6NH isn***8217;t there can I just add 6NS?
#315 ·
Question on enhanced blue tooth coding, I would like to have visual for text message. I've looked through a lot of information but I'm still a little confused. I have a 2014 X5 and 2015 X5.
Coding steps call for deleting the 6NH and adding 6NS, if the 6NH isn't there can I just add 6NS?
Assuming car has 609 nav Pro (NBT Head Unit), 6NH will not be present and you will just add 6NS.
#317 ·
another question for clarity. with the e-sys tips it indicates to set E-Sys => Options => Settings => Program tab => Memory Requirement => RAM is set to 1024 or you will likely be unable to read BDC. Do NOT use anything larger than 1024, or E-Sys will be unable to Open, and you will have to reinstall it.
after install mine has defaulted to 2048, I've input 1024 in the space then selected ok, then it says to reopen the program but then after reopen it has reverted back to 2048.
esys 3.27.1 launcher prem 2.4.3
this is my first kick at the cat so I want to make sure I'm not screwing anything up.
