1 - 6 of 6 Posts
I had read somewhere that the HK amp input from the head unit had some eq done to it and that the HI-FI did not.
Does anyone know for sure and does anyone know how to change the HU output coding?
Thanks in advance.
Discussion Starter #5
You want to downgrade Audio system through HU settings?
Apparently the output on the HK coded head unit has a modified signal and on the Hi-Fi the signal is untouched. I am not sure of why this is but if there is a way to get a cleaner signal for an aftermarket amp I am all for it.
Super Moderator
The "hi-fi" system to which I have listened subjectively sound awful. If you want a cleaner sound, it is more about music source and proper EQ settings.
Each factory option has a matching SALAPA. Just change to desired and VO code to experience difference.
Though, additionally, not all HK systems are the same. An F22 does not get amp like an F82.
1 - 6 of 6 Posts
