1 - 4 of 4 Posts
Hay I have installed some EE front drl headlights replacing halogen headlights but only randomly it seems they will flicker once every now and again,
I have coded -
FRA_V_L_KALTUEBERWACHUNG nicht_aktiv
FRA_V_L_WARMUEBERWACHUNG nicht_aktiv
FRA_V_L_IS_LED aktiv
FRA_V_R_KALTUEBERWACHUNG nicht_aktiv
FRA_V_R_WARMUEBERWACHUNG nicht_aktiv
FRA_V_R_IS_LED aktiv
my thoughts are did I need to code -
could this be causing the problem?
or I have not coded any or the rear checks as the rear are total standard or do I need to code out all rear checks as-well?
Any help with this would be massively appreciated.
THANKS
FL is highbeam, NSL is front or rear fog light. I can't remember more right now, maybe some German speaking will tell you. You can try all possible lights or you can use google translate.
1 - 4 of 4 Posts
