F30 rear right turn signal fuse ?
1 reading
18K views 6 replies 5 participants last post by  Domo018
#1 ·
Hard wired 7pin tow bar electrics and over a month lost my car right rear indicator.
No voltage on site.
Is there a fuse on either fuse board in the boot or engine bay for the rear right indicator / turn signal.
#3 ·
BMW's have not used fuses on lighting for at least 20 years.
All lights are switched by software driven transistor switches. Your rear lights are controlled by the Rear electronics module - in the floor of the boot.
IN theory you should not be connecting extra lights directly - the system has a specific transistor and wiring for each individual light - and it measures the resistance on each so as to be able to detect failing lamps. Normally for a trailer you need the extra electronics module for that that controls only the trailer lamps.
I suspect that your rear module has detected a fault and has shut down that lamp circuit - but you should have a warning message.
Try disconnecting any wiring connection you made for that circuit and see what happens.
Cheers
Jim Cash
#4 ·
Thanks for sharing your knowledge Jim sounds very logical.
I've disconnected everything and it's still not getting any volvatage to the indicator.
If I disconnect the battery do you think the sensors will 're set them shelves.
Am I ok to disconnected the battery and 're connect and it still drive ect won't need to programme anything???
#5 ·
Hi guys, I've disconnected the hard wired towing electrics and soldered the wires back where I made the connections. I've put a new bulb in. I've disconnected the battery and left it for 10 mins.
And I still have no volts to the right rear indicator.
I have the warning that the indicator is not working but tried everything.
Has anyone any ideas diy without taking in to bmw and paying a fortune for which I think is a 5 min job
