1 - 3 of 3 Posts
Ryan Hendriks
Hello,
yesterday evening at 7pm with light blue sky with sunlight when I started the car the lights went on, sometimes this happens when I'm standing outside near the garage and it's a little darker there but the after a while they go off and the DRL is on.
But now they stayed on the whole time and I saw a lot of other cars and BMW's with only their DRL on. I found it weird.
I checked the window screen and saw no dirt or something in front of it.
Then at home I tried to code the sensor to "insensitivity" but still the same.
Then I tried the automatic wipers, turned the button on for automatic, put some water on the sensor and then they start wiping. So the sensor is turned on has it's power.
Ofcourse it was already darker outside so I have to wait today till it's clear sky again.
But as far as I know the sensor is used for both things, light and rain, am I correct?
And is it correct if I coded the sensor to insensitivity instead of normal or should I code it to very sensitive to keep the lights off as long as possible?
You Don't Need to Know
any chance you hit the fog light button? that turns on the headlights
  • Like
Reactions: rytec
Ryan Hendriks
Discussion Starter #3
Hello, that's a very good tip you give here. I will have to test this out but it's possible maybe I hit this button.
Thank you.
1 - 3 of 3 Posts
