1 - 5 of 5 Posts
Hey folks - I am building a racing simulator, and being a BMW fan, I have purchased a real BMW 428i, 2015 (F32) passenger seat to use in the sim-rig.
I have purchased a12V power supply (fuse inline), and wanted to know which pins I needed to apply power to in the yellow connector. Unfortunately I
don't have the harness, so I either have to connect to the pins directly or cut the connector off :-(
I want to be able to have all of the seat adjustments work, but will not for example use the heated set feature. I also want to disconnect the seat belt/safety mechanism/s
completely as to avoid any unintentional safety system mishaps (whatever they may be).
I see there are two wide blades in the connector which I assume are for power, but not sure on what the rest of the pins are.
Any advise, including a schematic of the seat would be much appreciates,
Regards
3ER馃挍DSL
Discussion Starter #2
1011369
BTW/ this is the connector under the seat I am referring to.
Regards
3ER馃挍DSL
1 - 5 of 5 Posts
