1 - 10 of 10 Posts
Does anyone have any pointers for coding folding mirrors on an F series car when locking or unlocking via the key fob?
I've coded the following within FEM BODY, but the mirrors will not operate automatically.
KOMFORTOEFFNUNG_FB
KOMFORTSCHLIESSUNG_FB
ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN
Thanks in advance.
Have you tried holding down the button on the key fob a little longer, up to 1,5s?
If you want this to open without delay code:
3053 PWMaster Komfort_Schliessen default value: 0F and new value: 3
You can alter that time as you like, every step make 100ms change
Discussion Starter #3
Thanks for the quick response.
Holding down longer has no effect. What's strange is the windows will open if I code this option but will not close. Mirrors will do nothing at all.
I'm assuming I'm missing something simple, but I'm buggered if I can see it.
Premium Member
Check to see if they fold if you press lock on the exterior door handle. That works on ours (fob doesn’t work for us as noted above).
I do not have the button on driver's doors to fold the mirrors.
Will it be possible to code them to fold after lock/unlock with car key?
How can I get to know if I have folding-capable side mirrors?
Premium Member
No, you cannot code them if you do not have button.
1 - 10 of 10 Posts
