1 - 3 of 3 Posts
Hello all,
Thought I would briefly introduce myself as I am very much a noob within this forum.
I just picked up my new F56 JCW - lapis blue, and am ready to get stuck into reconfiguring the beast with a little bit of coding...
I have the following:
- E-Sys with an appropriate token configured for the Launcher.
- Cheat code lists (seems to be out of date or my PSDZDATA (V59.2) is not current - unsure)
- PSDZDATA (v.59.2_PSdZData_Lite).
I would be very appreciative if a helpful member could point me in the direction of the latest (or correct version) of PSDZDATA files i should be using, as the lists of codes within the document I have do not seem to be present.
All help welcome!!
Bimmerfest Founder
Welcome to Bimmerfest! I've moved your question to our coding forum, you'll get more help in here.
Tim
Super Moderator
Assuming you have Premium Launcher, the Cheat Codes are found here: C:\Program Files (x86)\TokenMaster\E-Sys Launcher Premium\FDLCodes.
Changing Psdzdata will not bring new Cheat Codes. You only need Psdzdata >= I-Step. See Guide.
P3.59.2/ P3.59.3 = F056-16-07-502.
P3.59.4/ P3.59.5 = F056-16-07-506
1 - 3 of 3 Posts
