-FRM
AUSG_24_RFS_L_IS_LED to aktiv | LED Reverse Lights
AUSG_25_RFS_R_IS_LED to aktiv | LED Reverse Lights
Can't believe BMW still uses incandescent bulbs for the reverse lights on the 2017 models..
Yeah, if you just copy and paste the AUSG stuff in search, if it shows up, it's the module.Dont have that Module. I FEM_Body I looked for that and it wasn't there thats what it was on my F10 M5
I have to check under REM maybe there.
AUSG_24_RFS_L_IS_LED to aktivYou do not want to blindly change funktion FDL's. Coding is hardware specific.
You will not find those funktions in F2x, F3x, F8x ECU's. And, repeating yourself does not make it the correct solution.AUSG_24_RFS_L_IS_LED to aktiv
Find that in a module and you win.
Jimmy9980,Does anyone know what to change to install the LED reverse light in a F87 M2?
Coding Wise so no errors pop up in the IDrive. I tried searching but could not find a straight answer.
Rsnic is correct.I would, using E-Sys (and the Launcher, of course) do a search of the REM module becuase it may be in a different module. ALternatively, if you have NCD-CAFD tool (available on other threads -- another terrific product from TokenMaster), you can use it to search your REM NCD file, if you have saved it to your computer.
And to add one more thing, what is the specific input voltage and output PWM on the LED's you're using?Rsnic is correct.
Additionally...
You can search in E-sys but TM's tool is nice because it displays all possible options and werte values without having to select edit for drop-down menu.
I tried but I did pull my list from other vehicles that aren't F01/F02. I just noticed that there are codings for F007, F025, F030, and other stuff there too when I was messing with the codes to say F001 LED etc. So either you are wrong and you have no idea and want to be right or you are right but considering that I do see the other F2x, F3x there too means they could use the same module.You will not find those funktions in F2x, F3x, F8x ECU's. And, repeating yourself does not make it the correct solution.
No, Almaretto is right. Since F001/F010 chassis uses FRM module and F20/F30/F80 chassis uses FEM/REM module for front/rear. All FDL mappings in those ECU's are completely different. For F025 you either FRM (F25) or BDC_BODY (F15 etc.).I tried but I did pull my list from other vehicles that aren't F01/F02. I just noticed that there are codings for F007, F025, F030, and other stuff there too when I was messing with the codes to say F001 LED etc. So either you are wrong and you have no idea and want to be right or you are right but considering that I do see the other F2x, F3x there too means they could use the same module.
Coding is hardware specific. If you want to know which ECU's are shared by various chassis, you can check out a CAFD's Header for FP or see CAFD_ID's Tables.I tried but I did pull my list from other vehicles that aren't F01/F02. I just noticed that there are codings for F007, F025, F030, and other stuff there too when I was messing with the codes to say F001 LED etc.
I've given him some tips as have many others, but he chooses to ignore any advice and instead advises everyone to stop coding until HE figures it out; begging members on the other side of the globe to personally go to a dealer and beg for help from service to fix his problem.Coding is hardware specific. If you want to know which ECU's are shared by various chassis, you can check out a CAFD's Header for FP or see CAFD_ID's Tables.
Which ones did you use?The bulbs I used didnt throw any errors nor do they flash from the checks. The options are in REM I was able to locate them but left them alone since no errors popped up. Thanks for the info !:thumbup:
I wonder too, because every single car I have seen with aftermarktet LED's do suffer from flickering during bulb check (due to KALT/WARM uberwachung).Which ones did you use?
There are a few that are reputable and CAN bus ready but are most often not available in certain localities and have high price tags.I wonder too, because every single car I have seen with aftermarktet LED's do suffer from flickering during bulb check (due to KALT/WARM uberwachung).
Miami10,There are a few that are reputable and CAN bus ready but are most often not available in certain localities and have high price tags.
I know you are very knowledgeable but I think it's the reason why you shut me out.I've given him some tips as have many others, but he chooses to ignore any advice and instead advises everyone to stop coding until HE figures it out; begging members on the other side of the globe to personally go to a dealer and beg for help from service to fix his problem.
The F001 LCI have the most scattered, complex, and completely unique lighting control layout compared to every other chassis, very little reference can be used successfully on it even where there are identical master controllers or ID names.
