1 - 20 of 65 Posts
Greetings,
do you have any software for FA/VO Generator?
I have my friend car E70 with new CAS without VO and there is no other VO data on the other modules, when i connect with ISTA/P it says can not read VO from the car, and it asks for the VO XML file on USB...
Please help me to get it and load it into the CAS
File is in Attachment. Rename to xml, and delete the first 3 lines. ( i can not attachment xml file ) edit and save it. The filename must be: xmldb.xml
You need edit it for the car.
You must change the following:
-vinLong
-checkDigit
-model type
-buildVersion
-model ( E70 )
-paintCode
-upholstery
-all option, and eword
Discussion Starter · #3 ·
I am tring it now, I want to know how to get the checkDigit and checksum values
anybody help please --Urgent !
Discussion Starter · #4 ·
also the Eword ?? shall i use the same value in the file A105 or there is another value?
Discussion Starter · #6 ·
Thank you tankren
i want the VO for two cars
VIN 0B16538 E70
VIN A661622 E90
Really appreciate your help
Discussion Starter · #7 ·
Any update please .... i need help urgently
Premium Member
5UXZV4C50D0B16538 = Check Digit "U"
WBAPK5C56BA661622 = Check Digit "G"
Discussion Starter · #9 ·
Thanks Shawn, if you can provide me with these values also
checksum and Eword for each?
Premium Member
Ok. I just learned something. The check digit is dependent on the PC it is run on. You must generate your own. I have sent you the program. You will need to add the digit as shown here using "Q" as an example:
coding vinLong="5UXZV4C50D0B16538" checkDigit="Q" location="0240" time="2012-11-20T11:50:00.000000"
checksum>FP/checksum
The checksum is calculated. Just leave it as FP.
I have no idea on what Ewords you need.
No.
The check digit is generated ONLY from VIN long. You can this calculate with NCS expert.
Premium Member
Why with 2 different PC's then do you get different results when calculating Check Digit from same VIN?
Premium Member
I generate U & G on 1 PC, and different ones on another PC.
@ahmedmph, what are you getting for Check Digits with the same program?
Premium Member
But if it is the wrong Generator, how come it makes U & G on 1 PC, and the same program on another PC made different Check Digits?
Premium Member
Yes, why does it make the correct Check Digits one PC and not the other?
1 - 20 of 65 Posts
