21 - 40 of 65 Posts
Premium Member
I thought the same thing, and that is why I posted the original "correct" check digits, but then I talked to someone else, and he said it varied based on PC, and then he ran the program on his machine, and as you can see, he got "Q" instead of "U".
No idea why. Maybe he just made a mistake running it. :dunno:
Discussion Starter · #23 ·
i am now uploading the xml file based on checkdigit U which also appeared with NCS
i will let u the results
Please run NCS on both PC, and calculate. "FA Eingeben", "Calculate Checkdigit", and must on both PC the same result.
NCS is original Software, and give on all pc the same result. ( VIN Checkdigit is calculated with MOD algorithm, and the base is only the 17 caracter VIN ).
Maszika
Premium Member
I generated and posted the correct check digits with the program.
I just assume at this point the other person made a mistake using it.
Discussion Starter · #26 ·
it didnt work, it says invalid work order
please help me generating it
Discussion Starter · #27 ·
the error message is invalid work order elements
Discussion Starter · #31 ·
i just tried now, it is accepted, but the ISTA/P is giving error in reading control modules
unable to detriment the installed modules?
any suggestions?
Premium Member
You don't generate an E-Word.
E-Words are developed by BMW AG, same as Factory SA Option Codes.
Hello.Mabye someone can help me to.I have same problem no VO in cas module and lma module.Can someone help to get my -checkDigit and E Word with my cars vin code WBANC71070B623458
Hello, can somebody create the original VO (vehicle order) for my VIN: PY33372
for import in BMW ISTA-P. ???
It must be a xml - file for the import.
Thanks !!!!
Premium Member
Premium Member
21 - 40 of 65 Posts
