Here waths happening (sometimes):
It only happens with a hot engine, from time to time:
The temperature meter goes in red, the handbrake led turns yellow, the car cranks but won't start.
My first idea was a bad temperature sensor, so I replaced the temperature sensor, tought it was ok but a couple of days ago, on a hot summerday it happend again. Sometimes it helps when I turn the key over and over again, suddenly its all normal, sometimes I have to let cool down a couple of hours. The cooling system is just worling fine, engine temp. is ok.
I read a simmilar case on the net and the sollution there was a bad rlay (the bleu one next to the ECU) I ckecked that one out but works just fine!
I'm guessing the car has an electrical problem or a bad sensor, connector, relay... but I could really use some hints here, its strange it only comes with a hot engine. Deu to that I think I can ignore any brake/abs problem?
When I read the OBD I only get a error code from the swirl flaps, they are gone be rmoved in the summer hollidays.
This is a real sticky problem for me, so any suggestions wil be welcome!
THX!
THX!
