What is the easiest way to remove the fan clutch? I read somewhere else on a video that they guy had taken off the four 10 mm nuts and got it that way somehow. So i tried that and all that is loose is the plate that they screw into that covers the water pump pulley. I did read about the fan clutch tool and i bought one now but its a PITA to try to get those four screws back in and then put the tool on it. Is there any way it can be done without trying to put the 4 scews and plate back on?
Also i have already loosened the belt... if that matters
